Getting her started. 91H-92C Force 90
Mickey13
hi guys. I know this is probably beaten to death. im just as dumb as they come.
91H-92C Force 90 serial no. 0E0000001- 0E065371 (no plate on the engine identifying it)
i sprayed starter fluid in the carbs and jumped the solenoid straight from the battery. she ran for a couple of seconds so guessing my clicking when turning the key is bad connection/bad ground? or is the solenoid still in play for replacement?
Mickey13
just bought a new battery. she started up when I jumped the solenoid direct from the battery.
thinking problem is wiring? or should I still replace the solenoid for good measure?
she wouldn't start when I jump the solenoid with just a screwdriver
Mickey13
bad connection at battery terminal. guy i bought the boat from said it was starter. i had already replaced starter and solenoid. both were fine.
next is to install the tilt trim i bought.
will be back probably
Mickey13
she is starting fine now. was a bad connection at terminal.
thank you for all your help though!
