Tom Kazakoff
Thread starter- Joined
- Feb 13, 2020
- 9
The engine is a Mercruiser 357 Alpha 4v. While running, the engine will start to speed up. If I back off on the throttle, it will speed up again after maybe a minute. This continues. After trolling for a couple of hours, the engine will do the opposite. If I am running at 18 mph, soon I will be at 16...until it gets to about 12 mph. If I back off the throttle, than accelerate, all is good. This pattern continues.
Prior to this behavior, after trolling, the engine would run fine for about 10 minutes, then it would decelerate to around 5 mph.At this point I could not accelerate at all. The engine would backfire, and miss violently. I changed the sensor that is inside the distributor. This caused the engine to go from the backfire, missing to run as described above. Prior to the new sensor, the engine still did (does) the "accelerate on its own" behavior
Salmon season is coming soon and it would be great not to get stuck 20 miles from the harbor again..
Thanks,
Tom Kazakoff
Thanks,
Tom Kazakoff
