Riley C
- Joined
- Dec 23, 2018
- 239
Hi Guys I thought to start a new thread being a totally different issue to the water pump.
On my 98 150 60 Degree Looper.
For some time I have thought the idling has been a little rough, I have always had WOT @5500rpm. Except for on the weekend it dropped to 4000 max. I cleaned down the plugs on the water, thinking one had fouled. It was fine for most of the day after that.
The accessories gauges on that same day dropped out while engine was running, but came on after turning on off again. Maybe a bad ground? This has only happened once and not again since, with multiple starts etc over the week.
While starting her yesterday in the test tank, it did have a rough idle, mainly during startup.
I pulled the coils down and tested with the spark tester, I get 7/16 on all of them with nice blue spark.
So thought to test the coils. The number one coil has infinity resistance reading, the primary (Power Pack Terminal) grounds with 0 ohms. However, I get infinity reading when testing the primary and secondary terminals together. The manual states 275+-50. All the other coils read at 295-299.
The coil of worry Secondary or spark plug terminal, turns in the coil housing for some reason and figure it is broken.
This coil I feel may be the source of why my max rpms dropped out on the weekend. That plug however, did not look fouled out and has a good burn colour.
My question is can you have no polarity or ohm reading but have a decent coil still?
Stator tests were fine, have not done a DVA on power pack.
Stator charges to 14.7volts. Never an issue cranking her over.
I think this motor even with low hours and good care, has ignition issues.
Either way I will order a backup.
Any recommendations?
