76 Evinrude 15hp needle valve seat?
merkdawg0084
Ok so my carb kit is supposed to be in tomorrow.Trying to get a jump on things. What is the best way to install the needle valve seat? Can it be put in backwards?
Thanks
hardwater fisherman
They only go in one way. There is a flange. I use a wood chisel to get them out.. If you have a very wide slot screwdriver then use that. I found my widest screwdriver was just enough but the chisel works well.
merkdawg0084
I called it a needle seat, bc actuallly it seats the low speed needle. Sry for the confusion.
hardwater fisherman
I just use the needle to seat the bearing. I do not know if that's correct but it worked for me. BYW The narrow end goes in first.
merkdawg0084
76 Evinrude 15hp slow speed needle bearing
Ok I posted yesterday, but didn’t clarify the correct parts . Is there a specific way to put in the plastic needle bearing? Can you put it in backwards? Thx
JohnnyGuy
Small end goes in first. Just like your needle.
It should fit like a cup over the end of your needle (if that makes sense :)) (refer to Post #8 and photo).
