JASinIL2006
- Joined
- Feb 10, 2012
- 5,763
Normally, mat side goes down to help bind the cloth to the surface you're glassing. I used 1708 for tabbing. CSM just doesn't have strength, so it doesn't help much to tab with it.
I would put a layer of csm /poly on the bottom side of the deck ply before installing . Then tab into the sides with 1708 .
Youcould get away with just a couple layers of csm on the topside if you want . Or use the 1708 ..
Yes poly alone will just crack . The 1708 will leave the weave pattern that’s all . Some like it to add texture for non slip..
‘Totally up to you really
1 csm on the bottom to seal it up then one 1708 on top . Look at it . If you don’t like the texture you could add a layer of csm over that to smooth it out .
‘Or for the topside install a layer of csm first then the 1708 with the csm side facing up .. Wet on wet layup ...
Just guessing and because you need to bed in around the edges with pb at least 3 gallons or so . The pb will burn the resin up quite a bit . That’s just a guess ..
Looking good so far! Subscribed to keep up with your progress!
You can use the surfacing wax on the final layup to help it cure.....that is if you are not painting it or gel coating it. If you use surfacing wax and you intend to add another layup, gelcoat, or paint, then the wax must be removed. In general, surfacing wax is not used in fiberglass layups. The place I bought my resin only gives it to you if you ask for it, and never adds it in the resin or gelcoat they sell.
