bugelingkayaker
Thread starter- Joined
- Nov 13, 2019
- 49
dear god i just screwed up with my 1973 merc 850. i was working on fine tuning some stuff with it in my driveway and running it on the hose. in between short runs, killing the engine, tweaking things and starting it up again, i was turning the hose off after killing the engine (trying to save a little water) and then turning the hose back on to run it again. well apparently going back and forth like this was stupid because i forgot to turn it back on one time and proceeded to run the engine for about 1-2 minutes before i realized what i had just done. freaking out i turned the water on and then started the engine hoping to cool it down. in retrospect that may have been about the worst possible thing i could have done (thermal shock).
so anyways here i am now about 15 minutes later kicking myself and doing a damage assessment. ran a compression test on all 4 cylinders and by some miracle compression is still good (140 on all cylinders). I tried to start it again after the compression test and it wont start. i'm praying that i might have simply flooded it with fuel during the compression check and i'm gonna let it sit for an hour before i try starting it up again.
anyways clearly im a bit panicked here. this was a project boat that i got back in october, when it wasn't running, have spent 100's of hours working on only to screw up right when it was nearly ready.
so what are your thoughts? since compression is still good, does that mean i might have miraculously dodged a bullet here and not damaged the head? i'll obviously be taking a look at the impeller and replacing that, but is it possible that MAYBE because i had just been running it on the house minutes previously that there was still enough water inside to have prevented any serious damage? is there anything besides your cylinders, pistons, rings, and your water pump assembly that can get damaged by running dry?
thanks for any info, words of encouragement, or condolences.
