chartersj
Thread starter- Joined
- May 14, 2013
- 301
While I have the engine out to clean up the pulleys I'd like to remove the air actuator water drain system. One actuator is on the back of the raw water pump, made of brass which is bolted to a metal bracket which is bolted to the motor. the new pump back is made of plastic. Will it be fine to bolt the new plastic backing plate to the metal bracket it which hangs off the motor, basically sandwiching the plastic backing plate? To remove the other actuator all I need is a 6 inch piece of 1"1/4 OD pipe.
