Multiple water pumps?
JR74CJ5
Hi all,
I'll try to keep the story part short and to the point.
I have a cabin cruiser appolo with a OMC cable shift stinger, and Ford 302 V8. I just replaced the seals and impeller in the sterndrive with the shafts (yes they were stripped) and got it back on the water after quite a long story.
Saturday, everything ran great, however I did get into a bit too shallow of water at one point and didn't notice right away. However, it ran fine rest of the day and ran another 2-1/2 to 3 hours. May have got some sand in there though (insert cursing at myself here...)
Sunday it ran great all day morning, actually came across another boat with his family stranded on river, towed them to closest ramp, got back on track down river and slowed down for a 5 mph zone, and noticed it got hot. Shut her down and anchored.
Disconnected the hose from the sterndrive into the engine compartment (after it cooled a few hours) and quickly tested flow with fast start - great flow. Noticed I also have a Jabsco 2620 belt driven pump. Again long story short I found the flow was restricted through that Jabsco pump and bypassed it to get home. It ran great 2-1/2 hours back to my boat ramp, idle and 3500 rpm consistent @ or under 140 degrees on dash gauge.
I can rebuild the pump, good there, my question is just what is the purpose of this instant prime additional pump? Is it a redundant extra to ensure good upward flow from the bottom of the engine compartment to the top thermo tree distribution? It seems to be a 3 pump system - sterndrive impeller, this jabsco 2620-1001 and the "regular" water pump for feeding through the engine block.
I couldn't find great reference to it anywhere in cooling system diagrams. My service manual got half eaten by rats (another long story). Need to grab a new one.
Thanks for your time.
Cheers - Jr
my guess the OMC motor was replaced with a volvo penta with the in-tact raw water pump.
post some pics
JR74CJ5
post some pics
I'll try - let's see if this works.
The photo of the front of the engine - the "extra" pump is on the bottom left by fuel pump. The other photo is the back plate of the Jabsco pump. The orange water line is the bypass patch using what I had on hand. Went straight from sterndrive inlet to the thermo housing tree and the thing never got above 140 at any speed, and was consistently under, in 70 degree river water.
In case any of that information helps...
JR74CJ5
I guess I should double check - assumed it has a Ford 302 for the inboard portion. It was my uncles, now it's mine - still trying to decipher what I have fully. Should have seen me trying to figure out what out drive year was with a tag that cross-references to nothing... that was irritating.
Ayuh,....... Whatever ya got there,..... You only need one raw water pump,.......
'n I don't see a distributor,..... Looks like a SBC to me,....
its not a ford, either a 307, 305, or 350.
would need casting number from the block
before using the boat, I would sit down with your uncle and ask "Whisky Tango Foxtrot".....
try to find out the story from him to help you figure out where/when/why the frankensteining started
JR74CJ5
Thanks Bondo - Kinda where I was going with that. Not sure what the purpose of two would be but figured I'd ask in case I was missing something...
And you're right on the distributor. I know better...
Scott - been boating on this thing for quite some time. He got it from a family friend who wouldn't remember at this point. I'll check out those casting numbers and find out what I have for future ref. So you're thinking my running gear is not a stock set up from what I'm gathering in your above post...
Now is there really any harm in having them both running (back to the pumps question)?
Redrig
If it were me , I would ditch the Jabsco pump and just run a new water line from the intermediate to the Tstat housing , obviously thats working since you didnt overheat when you had the Jabsco bypassed. Seems redundant to have the other water pump in line.
