Hello,
I have a 1999 Mercury 200 EFI that I am having trouble with. I ran it for the first time this year last night and it ran fine for about 5 minutes. After that, it lost power and went to idle. I was running around 4000 rpm on plane at that time. After idling around with no alarms, I got back up on plane and it ran for about 2 or 3 minutes and then died. Still no alarms. When I tried to restart it, it wouldn't crank and I was getting a fast beep, beep, beep.
Now, if I start to crank it and then turn off the key, I get the fast beep, beep, beep. I haven't let it start in case it's an oil issue.
I've verified the oil tank sensor is working correctly by disconnecting it and verifying continuity when the float goes to the bottom of it's travel. Continuity goes away when it floats up, indicating a full tank. Also verified both remote tank and onboard tank are full of oil.
How do I check the oil pump on the engine to rule it out? Any other thoughts?
Thanks,
Kurt
Thanks,
Kurt
