Boilers2000
Thread starter- Joined
- Jun 15, 2018
- 258
I want to add a second battery and was going to go with the Blue Seas ACR. I have a 92 SeaRay 200BR with a Mercruiser 4.3LX Engine. Looking at my wiring diagram it appears that there is a red/purple wire from the alternator to the harness and the harness to the cockpit that provides power to the fuse panel but also show connecting to the ignition (i terminal). This red/purple wire appears to also got to the starter salve solenoid in the engine compartment. Is the correct way to run a blue seas to:
1. run a new wire from the fuse panel to the Blue seas system that is powered by the house battery
2. remove the red/purple from the fuse panel and splice with red/purple that runs to the i terminal of of the ignition switch. In the service manual this is this red/purple is straight to the igniton switch with a note that is is where you would add a fuse panel.
Any insight is appreciated.
Thanks
Thanks
