Hello,
I recently purchased a 2000 alumacraft 165. It has a 2000 mercury 75hp 2 stroke outboard. I took it out for the first ride, made it a half mile and the motor quit. It would start back up, but wouldn’t stay running or idle.
Potentially unrelated to the issue the ignition switch wasn’t smooth, so I decided first step was going to be replacing it. I determined it was a 10 wire switch which isn’t made anymore, I found the part that replaces it. I wired it all color for color. Upon getting it all back together most stuff seems to be working (running on hose anyways). The one thing I have found is not working is the ability to push the neutral button, move the shift lever forward and still be able to turn it over to start it. Looking for help on troubleshooting this.
I haven’t worked on boats much and am not familiar with how this circuit works, but does the ignition switch have anything to do with this? I have one wire coming out of the ignition switch (I think it was a yellow/black wire) going into the back of the controls. I suspect that is the neutral safety switch wires, since it starts when in neutral without the lever forward is it handled in the controls for the part I am having trouble with?
Thanks for any info
Thanks for any info
