No Juice
Hashi
My '08 Tracker Marine Tahoe Q7i has been sitting for about three months of no use and last week I charged up the battery and tried to start it and the ignition switch does not make a sound. It doesn't turn on any of the accessories or crank the motor. I replaced the ignition switch and the main fuse with resettable button from the battery lead but still nothing. Not even a click. All leads have been tested for continuity and voltage and everything seems to be okay. Is there another fuse someplace that I'm missing? I also traced all wires that I can see and feel but still nothing. Thanks in advance for your help.
Rick Stephens
Time to disconnect and clean connections - especially grounds from the battery to the engine. Most likely a bit of corrosion preventing any connection. Pull the connections apart and clean em until you can eat off em.
nola mike
Not sure what you're testing, but if you have voltage, then you don't have a fuse problem. Where exactly are you/are you not getting voltage?
You sure the bat has any juice after being charged?
90amp fuse blow?
Ayuh,...... I couldn't Agree more,........ Shiny metal Clean,.....
