Will this fit my motor?
Some 50 years ago I had to explain to folks that the upper and lower are a matched set.-----They are assembled , then line bored as an assembly.----These are precision parts !----They must be , because no shimming is required when installing the gears and shafts.----It all fits perfectly because of the precision involved.-----Not an obvious thing to a novice.-----So will the bottom cap attach to your housing ?----Of course it will and it has been done many times.----Results may vary.------But a shop has to inform the owner that it may not work perfectly !
Bream Killer
Every time I log on to this site I learn something new. Thanks for the info.
