1980 Mercruiser 260. I have power to the red wire on the key switch when the battery is on. I have power to the purple wire on the key when key is in run position only, not start.. There is no power to the yellow/red wire in start mode.
The starter still has no power and won't turn over.
I now have 12 volts to the starter slave solenoid via the yellow wire with a red stripe. The starter still has no power and won't turn over.
