Mercruiser turns over, doesn't start unless I pour gas in the carb...
Status
Not open for further replies.
TwiceMyAge
Hi everybody, new here from Kelowna, BC Canada, and looking for some advice.
I recently inherited a late 90s 17' Maxum bowrider and with proper maintenance, I've had a few good seasons on her. It has a 3.0L Mercruiser Alpha One with Digital Electronic Ignition. I just pulled her out of storage and for some reason, she won't start. The situation:
-The engine will turn over easily, and if I pour gas in the carb it will run briefly before it starves out and dies.
-I'm getting fuel to the carb and it's under pressure (I disconnected the line briefly to check).
-I noticed that when choking I don't smell fuel, and no fuel is visibly getting into the carb.
I'm wondering if there is an issue with the choke or accelerator pump? Any advice or insight would be hugely appreciated. My apologies if this is a novice question! Learning as I go...
Thanks for reading!
Calvin
Squibbly
Sounds like dirt in the carburetor or jet.
Fuel in the bowl doesn't always translate to fuel getting from the bowl into the carb throat.
If putting gas into the carb gets it going, I'd start there.
What year is the motor or even better what is the serial number?
Need to check the fuel system
Remove fuel filter and see if there is anything but clean gas. You may have the upside down filter and it will all spill out so have a container to catch
Remove the fuel line going to the carb and place it in a container. Crank the motor over and see if any gas goes into the container. The fuel pump should push out a good bit of gas
Oldnbold
I realize you said you don’t see fuel delivery thru the venturi’s but are you certain?
I had a similar problem years back on my 7.4l on initial start up after winterization.
My problem turned out to be ethanol gas absorbing way too much water over time. I had also put new gas on top of old gas and still didn’t fire up. I had the carb off many times and I’d see puddles of fuel in the intake manifold. I thought I had a carb just dumping fuel making too rich to fire up.
I finally made an auxiliary, gravity fed source from a gallon jug, emptied the carb of old fuel then cranked. Within seconds it started and ran until I got tired of listening to it.
dumping the old gas was a pain
Thanks for reading!
Calvin
first, how are you starting it. be specific.
this is a carburetor, so starting is is more like a 1975 truck and less than any car after 1980
one to two full pumps of the throttle, press the throttle only button, move throttle to about 30%, then hit key
second, if the carb has sat for more than a year, you may need to go thru the carb and clean it. this will require a carb rebuild kit and about 2 hours of your time.
TwiceMyAge
Thanks for the feedback guys, I'll be checking it out this weekend.
Alldodge, It's a 1997, and the serial is 0K179423.
I have removed the line at that the carb and there's fuel, so there's something going on after that.
I have experienced this same issue last spring, but eventually she fired up and ran perfectly all season.
Thanks again for your help!
TwiceMyAge
That is more or less what I'm doing, although are you saying the first two pumps should be without the 'throttle only' engaged?
TwiceMyAge
Thanks Squibbly. Sounds like everybody agrees. Any good resources for a carb rebuilt kit?
Having a Merc carb it will have a filter behind the large nut. Remove the nut and check the filter. If filter is plugged, depending on the replacement type will depend on how its installed
To get the correct carb kit, look for a tag on the carb with a number
TwiceMyAge
Hi guys, thanks for all your help. I decided to try some carb cleaner before rebuilding or taking anything apart. It was getting close but still no dice. A friend popped by and suggested I pour a bit of fuel in the little channel circled in red in the photo as well as the main part.
That did the trick and she ran strong!
What is that part called and any thoughts on why that worked?
Thanks again, happy to be seaworthy again.
C
That's the float bowl vent, so your pouring fuel into the bowl. Will run until it uses the fuel up
The carb pic is for a TKS and you should have a Merc carb
TwiceMyAge
Yes sorry, I just googled the pic to show you guys. The boat ran strong for a good 30 mins or so before I shut it down, so it definitely delivering fuel once we did that. Maybe a stuck float or something?
Either way I think its due for a cleaning and a rebuilt. Happy it ran though.
C
Dobut its the float, think its either the pump or something is clogged
Do check the filter behind the large nut on the carb
Status
