Dallas214Stars
Thread starter- Joined
- Apr 5, 2020
- 62
Just got this Johnson motor is in the best shape of a motor I’ve had yet. When I bought it the guy said the amplifier was bad so I ordered a new one and hooked it up as what I think is correct according to a diagram I saw. Problem is someone already tried to wire the old one up which had different colored wires that are not OEM so I have no idea if where I have them plugged in is correct. The motor will turn over when I jump the starter but does absolutely nothing with the key on the controller. I’m assuming this hydro electric has something to do with the ignition hence it says that on the amp. The flywheel has a spot where the chord could wrap around but even with that it won’t start. Can’t figure out why it cranks but won’t start no matter what I do I’m about to mess with the ignition switch to see if that was wired incorrectly. Thanks for any help.
