awalkertx
Thread starter- Joined
- Apr 16, 2007
- 19
New thread
and I apologize for bringing up the old one.
I've got a 1997 Cobalt 200 with Volvo Penta 5.7GL PLKD motor and DP-S 1 out-drive... Counted the intake bolts and it's a first gen SBC. Obviously the Vortec is a superior head design and as such a better power plant, but given that mine's a 350 should a 4bbl swap be something to undertake? I have no desire to swap engines (or heads) at this time because it's all original and low-time.
I've looked at the specifications for the 5.7GL vs the 5.7GS and see a 215HP v. 250HP for the two. I have the shop manuals, which includes both power plants, but it only shows that the GS has a 4V carburetor vice the 2 on the GL. I have googled far and wide for any other differences between the two engines and really can't come up with anything other than carb and hp rating.
Boat has been dormant for a very long time and rather than rebuild the carburetor I was thinking about doing a swap to a four barrel. Earlier posts suggest that the Holley 4175 might be a good option, at least in the thread for the Vortec 5.0 that I should've left dead.
Looking at the parts catalog for my 5.7 liter engines model "LK" it looks as though the intake is shared between the GL and GS.... I'm assuming Volvo used a common one with an adapter like they did with the Vortec motors. VP 5.7GS calls for a P/N 3855279-0 Carburetor assembly... as far as I can tell, that's a Holley 4175 based on my googling but much of that is just based on advertising being bumped to the top.
Thanks for any input from the gray beards (or any slick-faces that happen to know). I'd sure like to go from 215HP to 250HP if it's a simple carburetor swap.
PS, again I can't tell a difference between the GL (limited power) power plant from the GS other than carburetor. Page 5-35 from the workshop manual gives same specs on cam, rocker arm ratio, base timing etc...
