RaceCarRich
- Joined
- May 31, 2015
- 234
2005 Bravo 3, using same Martry aluminum anode part numbers as past years. Big flat one towards the bow, the one fastened by 2 hex bolts....
I know it probably doesn’t matter but should I be concerned that it doesn’t lay flat? With the bolts in but loose it sort of sea-saws. Used a scotchbrite to clean up the area and remove any loose corrosion or dirt. Tightening bolts doesn’t help. Took it home and laid on a flat piece of 1/4” aluminum plate and the anode isn’t flat. Pressing down where the bolt holes plate are has one leg up >0.050”. Pushing that leg down pushes the opposite corner up. Seemed worse than that when putting on the drive.
I know conductivity is through the bolts and it probably doesn’t matter functionally but would you be concerned?
