Outdrive Replacement White Sealing Compound to Mounting Bolts
TulsaTime
Volvo SX manual states to apply "White Sealing Compound" to the stud bolts.
Is this the correct compound? See Pics.
Thanks
muc
"Retired" Association of Marine Technicians...
Thanks
No.
If you boat in salt water, use gasket sealer. If you’re mainly in fresh water don’t use anything.
muc
You haven’t asked yet. But I’m guessing you will get to the pivot pins. Use only the recommended locking compound on them. Gets really expensive when a DIY guy skips that step and they come loose out on the water.
TulsaTime
Thanks Muc!
Yes, I'm in freshwater. And I'll look into that threadlock for the pivot pins.
Appreciate the help.
