Canufixit2
Thread starter- Joined
- May 20, 2016
- 100
Hi. I'll try to be short and specific ... I have a 18' pontoon with a 2018 60hp 4S Mercury with Command Thrust. I WAS running a Quick Silver Black Diamond Propeller Black Finish, 14 dia x 11 pitch, Right Hand Ran well with Max RPM at about 5800 and I was happy with this prop - although the Max WOT Rpm was a tad low.
I ran across an Ebay real bargain - a new SS VENGEANCE (14 X 10") MERCURY RH PROPELLER, 48-17310A46.
It Installed OK using a new Quicksilver 835257Q9 Flo-Torq III Hub Kit. Now New MAx RPM WOT at 6000.And, I like the New SS prop for smoothness, esp at idle, etc.
One issue, On full stop with WOT acceleration (hole shot?) I believe I'm getting some Ventilation for approx 5 seconds. Rpm seems to accelerate faster than my old Alu prop - and seems to spin up faster (rpm) and then "Bite" and take off. Engine is full down/in. Propeller does NOT have PVS (Propellor Vent system/holes).
Is this Normal? As this did not happen with the Alu Prop. Comment ? Suggestions ??? OK to use as is ???
