Fishjustin87
Thread starter- Joined
- Aug 7, 2018
- 113
115 Johnson J115TLARC. So I have been trying to get my 115 timing properly set. I warmed it up and then pulled the plugs. Used a 7/16 gap tester on cylinder one and via Joe Reeves method set WOT to 24 degrees BTC. I should note that I used a piston stop tool and my pointer was on. With a friend running the boat and the cowling off I used the timing light and could not advance the motor past 32/33 degrees BTDC. I could get the pick up timing to 4 Dehrees BTC like the manual says but if we went WOT and then backed it off to idle the pickup timing would hang up around 7 or 8 degrees BTC. If I pressed on the advance lever back to where the idle pickup screw was than it would go back to 4 Degrees. I have no more threads left on the WOT advance threaded rod. What did I miss? Could my timer base be the cause? Should note the linc and sink all seems correct to the OMC manual
