Re: No shine on gell coat
I actually just got through doing this to my boat. I have not used the DUX 65 product, but if you use a 3M product,Use the Super Duty 05954.<br /><br />If its a dark color like black, you may have to go over it with a finer polish when done, but if its a lighter color you will be fine. Seal it with Meguiars #7 Show car glaze,(This really richens up the color), then follow up with a carnuba wax.<br /><br />Now, here is a tip. Rubbing compounds have oils and a lot of moisture in them that will penatrate the gelcoat while you are polishing. Soak a kitchen towel sized towel with laguer thinner and polish a small spot about 20 X 20" then wipe the area with the laquer thinner. This will remove any oils or moisture from the area and show spots that are not done yet. Hear again, lighter colors wont show this so much, but my boat is a dark grey on the sides and it was a B*itch to polish to the point that it looked new. If its really faded, (rough to the touch), you should actually wet sand the finish with 1500-2000 grit wet paper before polishing.
