ryno1234
Thread starter- Joined
- Dec 8, 2014
- 167
I just replaced my exhaust bellows with a new one. While tightening down the hoseclamp, the exhaust bellows is squeezed off of the mounting point on the pivot housing. This is the only place it does this. It does NOT do it on the transom side of things. That clamps down fine and holds the bellows in place.
I did this relatively soon after putting the bellows adhesive on (maybe 5 minutes after). That adhesive tacks up REAL quick so I figured this would be enough time to hold things in place while tightening the hose clamp. No such luck, it started to move the bellows away from the pivot housing as I tightened it more and more.
Is there a trick to this? Should I let the adhesive fully dry before cranking the hose clamp down?
