1986 force 125hp carb rebuild kit?
Anyone know of what kit I need? The one I see has a part number of FK10103 some say FK10103-2 but I don’t necessarily need all these metal parts nor do I want to pay $95 per carb rebuild. All I need is the o rings/gaskets to be replaced. I can clean all the metal myself. Where can I find just these parts?
Redbarron%%
Bowl Gasket - FO15623 1 x # of carbs
Bowl screw gasket - FO5323 2 X # of carbs
Carb gasket - F440906 1 X $ of carbs
Check the part numbers as I am not sure of your engine. These are for a 1986 125 hp
Do these seem like the right gaskets for the carbs? Also are these the only gaskets that are in there? I wanna order the parts before I take everything off just to make sure I have them all prior to disassembling. Here is the model and serial number to the motor:
Model #: 1258V6A
Serial #: 1160
jerryjerry05
They look like the right stuff.
But they could be for an 85 or carb for a 50??
Do they have individual part #s?
Redbarron put some part #s up in his post.
They seem to be right.
I’m trying to figure out the part number for the little rubber stopper that holds the jets as I heard they fall apart the easiest and will clog. Any idea of the part number for that?
jerryjerry05
Don't remember anything like this in the older carbs???
How about a pic of the pieces your looking for?
Later years had a jet accessible from the outside and it had the white plastic plug.
Pictures of the whole carb?
Well it was in a video I watched I haven’t taken them off yet because I wanted to have all my parts together before I do that. Let me see if I can pull up the video and show you what I’m talking about.
Also I’ve been reading about adjustments and I’ve read about this idle air screw I can’t find any videos of adjustment on it what do I need to do to sync this and what is the end goal?
Here is the guy fishing out the piece I’m talking about
Redbarron%%
That WAS the seat for the float valve, but not any more. You need new seats. Those used the solid steel valve pins where the new ones have a viton tip to seal the valve.
I hope you can still buy them
jerryjerry05
This is not a little rubber stopper that holds the jets.
This is the seat for the needle and seat.
IF??? it's not damaged(yet) leave it alone.???
Looks like you killed it:(
You might have ruined your carb?
The reason you can't find the part# is it isn't part of the jets.
It's a part from the older style carbs.Needle and seat.
It's NLA
I would try Franz Marine
He can get/has some of the older parts in stock.
