NatedoggAZ
Thread starter- Joined
- Mar 7, 2018
- 182
Hey All,
I just installed a new master dual battery switch on my boat. Everything is wired up through the new fuse block - except for the trim pump - that is direct connected to battery.
Off the fuse block, I have a new radio, 300W amp, blower, and a USB/cigarette lighter socket.
I am only using 1 battery now - but wanted a master switch to expand to 2 later if need be...
OK - on to my question:
Do I need to install an in-line fuse from the battery to the fuse block?
I have one already with a 50A or 60A fuse in it - I just have not yet put it on if needed.
I am using 8 gauge wire from the battery to the block on a 20ft boat - so the wire length is maybe 18ft including slack.
Thanks!
ND
Thanks!
ND
