MarvinGabriel
Thread starter- Joined
- May 5, 2020
- 83
Nope. I haven’t checked timing. I haven’t had a timing light since cars started timing themselves. Lol
Yes...about -2 degrees. So, what you are saying is:
1. The carb does not actually leave idle until the throttle is almost to the cold-start point?
2. The timing still advances well before that point, and should be at about 6 degrees when the throttle begins to advance?
If adjusting the timing to 0 deg as explained in previous post that gap between the white roller and the throttle cam shoud decrease a bit,but will never touch at idle. Tohatsu 2 stroke motors with throttle cams. levers will never touch at idle, the pic speaks for itself...
Check the gap between the white roller and the cam, that's at min throttle grip position or idle with readjusted 0 deg timing advance from original -3 deg.
Happy Boating
How many hours would you say the motor has run since day one ? Would suggest doing the following. Remove the air silencer from the carb, drill a 3 mm hole right in middle of the air silencer to match the middle of the carb's throat. Order a can of Engine Tune Up CRC brand, Sit motor on a stand or on the transom at terra firme, start the motor and let it warm up say min 3-4 minutes at idle flushed with ear muffs..
Connect the red cannula to the CRC can, insert it through the tiny hole just drilled and spray several short squirts of product one squirt at a time while the motor runs geared forward at the starting throttle grip position. When spraying motor will tend to miss which is quite normal, let the motor recuperate the idle rpm after each indidual squirt before spraying the second, third and so on. Spray the product liberally all you want, when the motor has had enough, keep pressed the can valve till the motor drops dead. Let is soak for some hours.
Start the motor and run it at idle or geared forward till the heavy fumes dissapears. Put the boat on water and go for a wot spin as if stealing it for say 2-3 minutes to clear the product leftovers inside the combustion chambers. The motor should rev much smoother at any throttle setting and at idle as well and in some cases restore power loss.
Usually install new spark plugs after the smoke has cleared before putting the boat on water. If the motor is healthy will pur as a kitten. If happen to have installed new spark plugs skip it. It's much better to test motors with muffs geared at idle, fast idle or bit higher at load that just at neutral/idle no load. Hope that CRC will do tis homework right and get rid of those smal symptoms. if plan going for CRC decarbon, report your findings..
Happy Boating
Will do. I suspected as much, due to the smell.
Sea Foam is effective if used on constant basis mixed with fuel, if no decarbon product has been used before CRC will take care good care of the M40C. Can spray through the carb's air silencer less product squirts each 50 run hours.
Happy Boating
