superfets
Thread starter- Joined
- Mar 6, 2017
- 139
Hi all, thanks again for all your help.
So I hit a rock and put a hole in the front of my alpha one gen 1. I still managed to drive 20 miles back to the cabin. And then another 10 mile to a boat launch get it home. It still worked like normal but sure sounded rough.
At home I took the whole out drive off the boat. Split the upper and lower. Didn't find any problems in the upper. So got a used lower. Installed a new impeller. Re-installed it. When I re-assembled it I made sure the washer was in place. Made sure that the shift gear was in forward by turning it clockwise with my hand and the turning the prop shaft counterclockwise and feeling that it was fully engaged. And when I mated the two back together I made sure the other majiger was lined up straight so that it would line up the other majiger with the throttle in forward when i re-installed the two halfs onto the boat.
Are you getting what I'm laying down. Then in the driveway on muffs I ran it. Shifted in to forward and the prop turned. Then shifted into reverse and the prop turned again. Back into neutral and the prop stopped turning.
Now today I put it in the water and only have reverse. I move the throttle into forward but the boat goes backwards. I shift the throttle into Reverse and the boat still goes backwards.
The one thing that came to mind as I'm writing this is that I didn't put the shift leaver into forward when I first took it apart.
Ok people. Please share your wisdom with me. Any and all thoughts are very much appreciated.
Thanks again.
Stef
Thanks again.
Stef
