Lancer76
Thread starter- Joined
- Jul 23, 2017
- 121
My 1976 MC-1 drive (SN 4518534) gave up the ghost today. The drive shaft still turns and there was not burned rubber smell, so the coupler is okay. With engine running I shift forward, and the motor revs, but no prop movement. Same with reverse. With engine off and the shift lever in neutral, prop spins freely each way. When the shifter is in the forward position, props spins in the clockwise direction with little momentary resistance and some clicking with the resistance. In the counterclockwise direction, there is more firm resistance, but I can overcome it by pushing harder on the prop. With the shifter in reverse, I can spin the prop in either direction fairly easily with a similar momentary resistance that is easily overcome.
I've read a few posts that suggest that my upper or lower are toast. I haven't taken the top off the upper. Is there a special tool that fits the 4 starred bolt heads on the lid of the upper?
I haven't taken off the prop, and while I would hope for a spun prop, I am dubious of that outcome.
So I think I have to find a used outdrive. My understanding is that an alpha one gen 1 upper and lower combo will mate to the MC-1 bell housing. Is that assumption correct?
My gear ratio is 1:1.50. If I find a 1987 1:1.5 alpha one gen 1, will that work regardless of what motor it was originally mated to (mine is a 233)?
Thank you. Any tips on diagnosing the outdrive issue would be appreciated. Also, will an outdrive SN be indicative of the gear ratio, and if not, how do I determine that?
