More Bravo overheating problems *sigh* Some advice before I haul the boat?
wildk
Hi everyone, so I am having more overheating problems with my boat. Sorry for the long post, but I would like to give as much detail as possible.
----------------Here's the background info about the boat/motor.-----------------------------
I have a 1997 Eastern downeast "lobster style" boat. The boat has a 2004 Merc 383 scorpion raw water cooled engine that I installed last year, keeping the 1997 Bravo 2 drive that was original to the boat. In 2018, the outdrive was serviced by the previous owner, replacing bellows, gimbal bearing, and all seals. From what I can tell, the drive is in great condition for a salt water boat. The motor has <100 hours on it since new, read by the ECU on the motor. Before installing the motor, I inspected the manifolds/risers for signs of deterioration, and they were fine. I also installed new exhaust flappers. The motor had never been used in salt water before I installed it.
This spring, I replaced the water pump impeller and housing as preventative maintenance, as the brass housing was rough and corroded. The old water pump sometimes had trouble priming itself when first started. Just launched the boat this weekend, and the pump primes itself great, but I am now having high-RPM overheating problems. I have done research into the symptoms, and I think it's a commonly described "Bravoitis" problem, but I am seeking other opinions before I haul the boat out to fix (no trailer so this costs me money)
-------------------------------------Here's the symptoms.-----------------------------------------------
Boat runs/cools great up to about 2000-2500RPM as measured by Tach on boat. It can idle/slow cruise all day without overheating. Increasing throttle past that point, and the temperature starts to rise. Once the temperature starts rising, the exhaust manifolds get hot, indicating no/limited water flow from the raw water pump.
Once overheating starts, bringing the boat back to idle will slowly cool the motor down - over a period of 5-10 minutes, but turning off the motor and starting it again will cool the motor very rapidly, in a matter of 15-30 seconds, returning the manifolds to cool to the touch.
I checked the thermostat, just in case, and it was not corroded, and seemed to be open at high temperatures. I didn't expect this to be the problem, but it is easy to check.
-------------------------------Here's What I did to test and diagnose------------------------------
I then pulled the hoses from the water pump to try to observe the flow of water. I first pulled the hose that goes from the pump to the engine. The pump has good flow at idle, but increasing the motor RPM does not increase the flow rate of the pump. If anything, the flow decreases as RPM increases. I would describe the flow as "less than a garden hose" at any rpm.
I then pulled the water inlet hose from the back of the pump and attached a spare hose to the end of it, routed over the stern and straight into the water, bypassing the water inlet on the outdrive. I still had the water pump outlet hose off the motor to observe the flow. Big difference this time. as RPM increased, the flow increased, to a point where it was probably flowing 10x what it was while drawing water through the outdrive. I would describe the flow as a "Fire Hose". I also inspected the hose that goes from the transom fitting to the raw water pump for obstructions and found none. I tried flushing the drive backwards with the dock water supply while the boat was still in the water, and the drive didn't appear to obstruct the flow of water excessively, although the raw water pump can move substantially more water than the dock water supply. With the outdrive water inlet bypassed, the motor was able to run high RPM without overheating.
It seems like my new, better flowing raw water pump is collapsing the water inlet hose in the outdrive, or it is full of obstructions, and these are symptoms of the "bravoitis" problem. A little research makes it seem that this kit is what is used to repair this issue:
https://store8666.americommerce.com/...epair-kit.aspx
I just don't have a good feel for what I have to do with this kit once I have the boat out of the water. Is there anything else I should check for or replace while the boat is out? Anything I can do first, without hauling the boat out? Either to fix it, or to confirm the diagnosis? I was also going to replace the seals between the outdrive and bell housing, in case there is any air leak there. Should I skip this kit alltogether and install a through hull water pickup? I don't like the thought of cutting additional holes in the boat. If you made it this far, thanks for reading!
Does sound like Bravoits or the inlet hose is kinked. If Bravoits it can be checked by removing the hose at the transom. The issue is I don't know how low the transom is to the water, so might have a problem. Being a fresh water boat until now I would lean toward maybe a kinked hose.
Click image for larger version  Name:	Bravo clogging.jpg Views:	6 Size:	182.7 KB ID:	10891150
There is another kit which I installed a couple years ago but didn't need to on my 95 Rinker. Being it salt water now, it might be best to do a thru hull so no longer need to worry
https://forums.iboats.com/forum/engi...bravo-itis-fix
wildk
Thanks for the reply. The boat was always a salt water boat, the engine is a low-hour engine pulled from a freshwater boat that was wrecked (a boatyard dropped another boat on it).
The outdrive has been in salt water every summer it's entire life, so that would explain bravoitis.
Now for that picture you posted, I am having a hard time visualizing what that is a picture of. Where is that? Not the junction between the bell housing and the drive, is it? As I understand, it is on the transom, (so like behind the bell housing).
I can't really get a good look at mine until it is pulled out of the water, which makes the visualization hard.
wildk
I think this is a good visualization of the hose that needs to be replaced from the outboard side. (Not my boat, just a picture I found online) Is it possible to do this job without removing the bell housing/ separating the bellows? I do not have all the specialty bellows tools, so it may be more cost effective to pay someone to do it if that is the case.
I was able to replace the gear lube hose as well as replace the trim sender and limit switch without removing the bell housing, which the official repair instructions would have you believe is not possible.
And this seems to be a good representation of the inboard side of the transom
The picture is the inboard side of the transom in your lower pic. The small fitting on the left is the lube bottole fitting, and the one next is the water discharge side that connects to the raw water pump
tpenfield
Symptoms are either Bravoitis . . . or 'possibly' some sea life (barnacle) has grown in the water passage of the outdrive . . , and detached . . . now is partially blocking water flow at the bell housing. BTDT :rolleyes:
tank1949
I just finished installing new kits in two Bravo 1s. If Bravo 3s are the same, you will have to pull OD and examine Bell housing's hose. On the motor side, you may be able to follow 1 1/4" hose to gimbal housing's hose barb and remove it, but a lot easier to pull motor to access it and what is behind hose barb. Behind barb is where you are going to see the night mare.
wildk
So would you say it's better to just install a through hull water pickup?
If it is barnacles clogging the outdrive, is there any solution short of buying a new outdrive? Anything that dissolves barnacles? I can't imagine you can really get in there with a brush.
tank1949
I agree on a new pickup via hull but then he will have to block off the existing water passages or barb. Used bravos are difficult or expensive to buy. New ones cost an arm and a leg. SEI makes Alphas but I am not sure about Bravos, especially 3s. I suspect the OD requires maintenance too (now is time to inspect and fix) and he could possibly do multiple tasks once bellhousing is exposed.
Being full time in salt I would install a thru hull and strainer, or at least the thru hull for now.
The block off plate is fairly easy to install. Only thing would need to do in the drive area, is cut the drive feed hose, so water continues to go thru to help cool the drive
tank1949
Accessing mine was a pain in the butt due to all the wires and hoses and metal in the way.
If I had enough room in bilge area, I'd would have added two strainers there. ​
Where do you cut drive feed hose? On my Bravos, sea water comes from lower unit into an upper cavity and then into bellhousing via hose. Cut hose on backside of bellhousing so that water freely flows out? Running at WOT, there is going to be a lot of water pressure coming from OD. Thx!
San_Diego_SeaRay
This is an off the grid suggestion but I'm going to throw it out there.
Why not remove the sterndrive and run a semi-rigid but flexible wire or hose up the water inlet on the gimbal housing (I'm thinking 6awg power wire or the like). If you hit resistance about 1.5 to 2 feet in, then this would be preliminary confirmation that you have a restriction there (Bravo-itis). Then you can try to clear the restriction (plumber's snake?). Then re-check your water flow at the thermostat housing to see if it has improved.
If it was me, pulling the engine would be my last resort. I know some people insist it's the easiest course of action (and it is for some) but most people have a hard time finding a suitable hoist setup.
San_Diego_SeaRay
Whoops. Just realized the boat is still in the water. Possible to do this from the seawater pump hose side? Accessing the transom plate inlet seems really difficult. Really tight back there....
wildk
So I hauled the boat out this weekend and started disassembling... Confirmed it's bravoitis. Could not get a picture as there is NO access to stick a camera down there, but it was pretty bad. Amazing water got thru at all. I tried installing the kit here:
Was able to get it 99% of the way without pulling the motor or bell housing, but the clamp around the stainless flange would not fit into the tunnel in the transom. Actually damaged the clamp on the hose while trying to install it all the way. It looks like the kit may have not been assembled correctly, and the clamp was possibly not fully collapsed around the tube.
Going to buy the quicksilver/mercruiser original part, and now knowing what I do, I know I will have the access to install the hose fittings on each end, and the motor "should" not have to come out... The old one lasted 20+ years, I am guessing this will outlast the rest of the outdrive and motor
wildk
I also wanna complain about this crappy plastic tool they give you to remove/install the threaded plastic inserts. It is simply not up to the task, and broke before I could get the bell housing end removed.
ACtC-3e5eZTT5ctI71yYmQcVUnWqYI6RGIoS3tB79PsNGi04yQCkFiZC08yoxJi0jzrJZFDhS5qGFB9WdruJB_1J6lhmHVhiwdJgD7VSPBKd_H228QsnhJrSArZzvIl2tn16piWKXOYEg5s7wKn9mMdiofb1=w652-h477-no
AF1QipOuh-ao_jCOnjQZWfHrv2_0dfrKvDv9qMB4ElRE
Recommend buying this metal version for anyone attempting this job.
*Edit: link broken, but part number is: [h=3]91-43579[/h]
tank1949
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"477","width":"652","src":"https:\/\/lh3.googleusercontent.com\/pw\/ACtC-3e5eZTT5ctI71yYmQcVUnWqYI6RGIoS3tB79PsNGi04yQCkFiZC08yoxJi0jzrJZFDhS5qGFB9WdruJB_1J6lhmHVhiwdJgD7VSPBKd_H228QsnhJrSArZzvIl2tn16piWKXOYEg5s7wKn9mMdiofb1=w652-h477-no?authuser=0"**[/IMG2][IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/photos.google.com\/search\/_tra_\/photo\/AF1QipOuh-ao_jCOnjQZWfHrv2_0dfrKvDv9qMB4ElRE"**[/IMG2]
Be sure to clean metal ports before inserting and apply lots of bellows cement. Before drying, it acts as a lube. It did for me. I also removed prior, as best that I could, aluminum corrosion, scuffed up, cleaned aluminum, primed and painted using binary epoxy (the real stuff).
Agree ts tight and the Merc kit worked pretty well, but do watch to not put to much pressure on the thin plastic hose.
Do agree, once changed you should be great for another 20+ years
