nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,127
I'm installing an electric fuel pump on my new '01 4.3L block. Getting a bit confused.
Plumbing:
1. I know I can use A1 fuel line after the pump to the carb. The pump uses 1/4" NPT fittings on both sides, and the carb uses a 3/8" inverted flare. Hopefully that's something I can get locally. I need to find a place to mount the pump. In a perfect world I'll be able to use the line from the 2bbl carb and mechanical fuel pump, and mount in a similar location. I don't have the '89 4.3L with me atm to look at...
2. What size fuel line? 3/8"?
3. Do I need a filter after the pump? I have a fuel/water separator before it. Edelbrock recommends a post pump filter, but it doesn't look like any of the V6 carbs even have the inlet filter (unless I'm missing it?)
Wiring:
I'm using achris diagram from this thread as my reference, as well as a few of Rick Stephens posts. The starter wiring on the v6 is different than on my 470, so not familiar with it yet. Also, that diagram looks like for a 2 terminal pressure switch? Mine is 3 terminal.
1. the plan is to go from coil (+) --> new electric choke --> oil pressure switch. Not sure about terminal 2 on the switch. Looks like it could either come from the yellow/red off the slave or the purple/yellow off the starter (that's the "I" terminal, right? Not sure why that exists in a TB IV ignition, I thought it always gets 12v).
2. Other side of OP switch triggers relay
3. Main relay power from red/purple off the slave
4. Other side of relay to pump.
I don't see a 90A fuse anywhere on the starter. Old one is at home so I'll check, but otherwise that should just attach between the red/purple and main starter terminal, right?
Lastly, does anyone have a pdf of the manual for the '89 4.3L? I only have the newer one, and can't access it on boatinfo. I'd like to look at the wiring diagrams...
Plumbing:
Wiring:
