I removed my 6 season exhaust manifold and risers off to inspect over the winter and have now just gotten to it. The boat is used about ten times a year in saltwater and usually flushed after each use. I noticed the two engine ports on rear of the 4.3 v6 are carbon coated while the other 4 ports have some level of rust as depicted in the following images. Also the manifold in the exhaust section has a fair amount of rust.
The first port shows the clean port rear of engine while the second two show both the engine side and manifold side ports rusted respectively. I will note the flappers were replaced with the manifolds and still appear to work.I realize it's probably time to replace the manifold while it is not breached from what I can see, I am concerned with whether this is normal for salt corrosion to reach this part of the manifold or even the engine? I would certainly expect all the ports to have the same level of corrosion or at least some.
Any thoughts or experience with this? I do not recall how the ports looked when I did the manifold the first time and are concerned with possible corrosion around the valves or even further.
Ken
Ken
