4.3 Merc Timing cover Help
Rick Stephens
I think the hump on top of the timing cover is for the balance shaft. The balance shaft came out starting in '92. I don't think that hump has anything to do with Vortec or non-Vortec.
rderenzy
Right. which mine has, so i need that bump. which is what worries me in buying just the rock auto cover that does NOT have the "bump" :(
Rick Stephens
Me thinks you are correct. I have not located a balance shaft steel timing cover. No balance shaft steel cover a dime a dozen.
rderenzy
RIGHT! which is what i'm trying to explain but i'm told to not over think it :D
i've had a certified mechanic go through 4 covers already, hoping this last one he just found solves it - i'll be sure to post w/ numbers and the outcome
nola mike
See, the weird thing is that the part number is the same for a '94 S10, which would definitely be balance shaft as for an '89.
rderenzy
HAHA see that confuses the hell out of me even more! haha
Rick Stephens
I get it. Also, no telling what Merc was buying from Chevy since they pretty much always trailed new motor improvements by at least a year or two. My engine is not balance shaft, but has the blocked off mechanical fuel pump mount. It is also, supposedly, a ;93 or '94 block. Definitely not a Merc sourced block though. A frankenMerc.
rderenzy
i'm still trying to figure out why my boat (a 1997) has a 1993 motor
but i dont know the history, i've only had it for 4 years
remember, the marine motors are a division of GM's industrial motors. the stamped 4.3 balance shaft timing cover may be from the natural gas gen set motor
could be a left over motor from a large purchase in 94 or 95 with your boat being built in late 96 or it could have been replaced.
when the economy went to hell in 2008, Both Merc and Volvo had an entire warehouses of 8.1 motors that were used in Mercruiser powered boats until 2011 and Volvo powered boats up until 2014 (GM quit production of the 8.1 in 2008)
nola mike
Yeah, but I don't see what would be different from the the balance shaft pre vortec GMs that would need a different cover. What isn't fitting? Very curious about this, and surprised nobody has the answer. Can't be that uncommon. I can't remember off the top of my head how the intake relates to the timing cover. That would be the only potential difference that I can see.
Rick Stephens
The balance shaft adds to the height. The non-balance shaft cover goes right around the cam gear. The balance shaft motor has an additional gear driven shaft. You can see it in the pic below.
achris
More fish than mountain goat
Ok, the original GM part number was 12523080, which was discontinued in Feb 2006. The replacement for that is 12509865. As yet, I can't find a source.
Chris...
achris
The link and part number Rick posted are the right one.
nola mike
achris which link, the rock auto?
You're right about the unobtanium GM part I think. The GM sites list different part numbers for balance/non-balance shaft engines. I'm thinking that whatever database these third party retailers (rockauto, napa, autozone,etc) is using is wrong, and listing the same part for all engines even though it won't fit the balance shaft engines. So the GM and merc blocks are the same and both need the same cover. Odd and sucks that it's discontinued without an aftermarket.
nola mike
But it looks like the gasket and crank seal are still available?
14090906
10108435
Yegboats
Here is the NLA list a place just listed they had one last month. I can't help with the automotive, all I can say is have them order the gm one from a local auto parts store, compare it to existing one.Return if it's different.
855400FNLACOVER-TIMING
Number Status Description
1GREENE MARINE REPRWILMINGTONNCUNITED STATES910-395-207402/12/2020
1A-ROCK PROPELLERSALT LAKE CTYUTUNITED STATES801-281-828806/19/2020
Qty Dealership City State Country Name Phone Number Last Updated
rderenzy
Thats a good question - i guess this 93-94 is a "special motor" a frankenstien i guess and have been told several times by certified shop that the auto parts will NOT fit this - they've put 4 covers on this damn thing and it leaks on each side, about 75% of the way up on the cover, where it tends to "dip out" (or not dip out) and there is a slight gap in coverage/seal
hopefuly they got the right part this time and i'll report out the facts!
rderenzy
BOOOOOOM! this is EXCATLY IT and why its not "over thinking"
as i mentioned in the pics i posted - the auto ones are round at the top, this is more EGG shape which is exactly whati need
GREAT find, thank you
