RideNFishCA
Thread starter- Joined
- Jul 8, 2020
- 15
2005 Merc 115ELPT4S four stroke 1B158433 - First time boat owner.
No warning horn, ever. No short beep at start up or otherwise. I removed forward controls (side mount) and made sure purple wire was hot with key on. I grounded tan/blu wire and horn went off. I am worried that previous owner hid something from me and I didn't have the experience to catch it. Last time out couldn't reach full speed and boat has no tack. Seemed to be running fine otherwise.
I found two wires unhooked at harness under cowl but I think those are for an analog trim gauge. I believe this is the Yamaha powerhead years hence the harness adapter from 10 pin to 8.
Can I try to force warning on water temp or oil pressure by grounding wires since I know the horn works at the forward controls?
Thank you in advance.
I have some mechanical experience
Moderators, please let me know if I can improve info for efficiency.
Cheers!
Cheers!
