brian36578
Thread starter- Joined
- Feb 1, 2016
- 59
Engine died on my 4.3L on Monday, pulled the engine yesterday and disassembled today to find it threw a rod and cracked the block. I have been interested in a 5.7L since I got this boat, and I believe I would have enough room (though it would be very tight, I had seen someone online say you need 8" additional space in front of the 4.3L to fit the 5.7L?) plus my uncle has a cracked alpha 1 stern that came off a 5.7L so I would be able to swap the gearing right away as well. Other than the sterndrive gears, what else needs to be modified for this swap? I am also trying to get back in the water ASAP since its mid summer so I might just go with a 4.3L short block, does anyone know of any place that sells reman 4.3L, ideally within a couple hour drive of SE Michigan? Also, would I be able to swap in a short block from a vehicle if I get the same year? I think this would be the cheapest and quickest route.
