So as the title says I purchased a 2004 Larson 230LXI with a volvo penta 5.0. Boat ran fine the 4-5 times i took it out and then it sat for a month or two and we had a ton of rain here in south florida. I didn't think anything of it until I tried to get the boat ready for a day on the lake with family. I do run the boat in the gulf and always clean and rinse with soap/water as well as flush after... Anyways I was shocked when i took the cover off and seen all the water. I knew it was such a rookie mistake. (Pic attached for your enjoyment.) Anyways I drained the boat and cleaned it up. Started it up and it ran fine in the driveway for 10 minutes. Thought all was good. Well I bring it to the lake, and of course fill the boat up with fuel, drop the boat in and of course it doesn't start.. try and try and nothing. I check and the belt snapped. So no boating for me that day. I order the new belt and install it. Try to crank and won't turn at all. come to find out alternator is seized. Get a new alternator and install it. Still have problems trying to turn over. Remove starter and install a new starter. Now it sounds great but still won't turn over. Change the old 8 spark plugs. Still won't turn over. Now i feel it has to be a fuel issue and water must be in the fuel. This is where I am now. I removed the fuel/water separator and filter was full of water. I am thinking water has to be in the lines. What can I do now? I don't want to drain the entire tank full of fuel. Anybody with guidance on what to do next would be greatly appreciated. I took the cover off the carb and its pretty damn black inside (pic attached). I know Ill eventually clean the carb but what can I do now to maybe get some water out and see if I can get it to turn over and run as good as she was before the boat filled with rain water. Thank you!
