Stuartvaguy
Thread starter- Joined
- Jul 6, 2020
- 17
I had recently posted about a stall after the boat is turned off that I've now determined is vapor lock on my 1999 mercruiser 5.0 efi serial number 0l340610. In addition to wrapping the fuel lines and allowing it to idle for a few minutes before shutting off, I am interested in adding the check valve that will prevent hot water from going back out to the fuel cooler after shut down. It is my understanding that they were installed stock on later mpi engines. I've also read one instance where someone found an aftermarket part but I'm not having any luck finding it. Can someone please guide me to this part? Thank you!
