Hi, first-time boat owner here!
I have a Mercury 50hp 2 stroke 4cyl that runs great all day then after sitting overnight iI can’t get it to start. It will crank and crank but no signs of starting.
I will park the unit for the week with the cowl off and spark plugs out. The following weekend the motor will fire right up. But, again I use the boat for the day, dock it overnight and nothing the next day...
I feel the unit runs to well to be a carb issue as when it’s running its performing at 100%. When chatting with people I get anything from rebuild both carbs to replace the stator.
I did replace the fuel and plugs but have not tested for spark when the issue is going on...
Thoughts? And thanks in advance.
savering
savering
