Txbassman83
Thread starter- Joined
- Jul 16, 2020
- 10
Please understand I am not a mechanic and may seem like a novice.
I am not sure what year the motor actually is but the serial# is Serail# M031816.
The boat is a 2001 Glastron ski/fish with a Mercuiser 5.0L Alpha Gen II.
It has been sitting for 2 years in storage and I have having issues getting it to start. In the past even with it sitting for few months up to a year, it would always start after 3 or 4 attempts and would run smoothly. I use Sta-bil fuel stabilizer with every fill-up.
I removed the top of the air intake and it is not getting any gas pushed to the carb and there is no smell of gas. I can spray starting fluid in the air intake and it will fire immediately. When I turn the key (alarm sounds but not trying to start it), I don’t hear the fuel pump run but I cannot remember if it is suppose to “come on” at that point or only when attempting to start the engine.
I did changed the Fuel/Water separator filter which was full of fuel when I removed it. I filled the new one with gas when I installed it. The engine still did not fire and still no gas to the carb. I unplugged the fuel pump and jumped it directly to the battery and the pump runs but no gas to the carb. I did check the voltage at the fuel pump wire harness and there is no voltage when the key is simply turned on. When trying to start the engine, the voltage fluctuates between 10.78 to 11.23 or so. I started looking at the starter and its solenoid and the connections looked rusted and I thought the 90 amp fuse may be bad due to the rust. I cleaned each connection and the fuse. The fuse had continuity so I reinstalled it but still not gas to the carb when trying to start it.
I assume that my fuel pump is bad (run but not pump) or the metal fuel line from the pump to the carb is clogged or the carb has issues. Note that I have never overhauled a carb and don’t really know what I would be getting into.
Questions:
Questions:
- Using the serial# M031816, can someone lookup and confirm my engine year, model and such?
- Should the fuel pump run when simply turning the key on (alarm sounding)?
- Is 10.78 – 11.23 voltage proper for operating the fuel pump?
- Does anyone have any suggestions what to do next?
