Redtruck12
Thread starter- Joined
- Jan 25, 2018
- 344
So due to Covid19 and a new job yesterday was the first day on the water for my Restored 1974 Duo Vagabond (140 hp Mercruiser 3.0 litre.
rented a cottage on Pigeon Lake in the Halliburton Highlands (Ontario). Shallow and weedy lake.
first run I noticed a bit of what I assume was prop shake from weeds which cleared after bringing the engine up to speed.
engine running fine but after about 10 minutes engine temperature climbed to 200f on the gauge.
I stopped and shut the engine off. Lifted the engine cowl and smoke was evident. Evaluated the source and pinpointed as VERY hot manifold.
checked for weed clogging the water intake on the drive - there were weeds.
limped back to the dock at not much more than idle.
question is now what?? What should I check? Should I replace the water pickup pump before running it?
I’m fairly confident I have not damaged the engine and would prefer to keep it that way.
next question is advice on how to avoid it happening again
