1997 3.0 having stalling issues half way through summer
oddcarout
Been using my boat with a 3.0 this summer and this week it has started hesitating when trying to accelerate. It will straight die if I don’t punch the throttle at least 3/4 wot. This happens in neutral or in gear.
what I have done:
new fuel/water separator filter
new spark plugs
new gas
new anti-siphon valve
cleaned the carb with spray cleaner
have checked, I get good spray from the priming pump
Any help suggestions would be great. We have a trip planned this weekend and hope to be on it.
thank you,
zachariah
1997 Maxim 1900 mercruiser 3.0 LX
dubs283
you sprayed the carb down with carb cleaner or you disassmbled, cleaned and reassembled the carb?
new spark plugs, but what about cap/rotor, wires, fuel pump filter, check and set timing/idle?
oddcarout
Sprayed the carb did not take it off, can’t tune a carb
changed the fuel/water separator filter
didnt touch the distributor since it is not loose it does not make sense to adjust it, and the cap looks fine, almost no wear.
the old plugs were gapped at .050 but the carb cover said .035 so I gapped the new ones to .035.
dubs283
can’t tune a carb...didnt touch the distributor since it is not loose it does not make sense to adjust it, and the cap looks fine, almost no wear.
carburetors most definitely can be disassembled cleaned and tuned
just because the distributor isn't loose does not mean the timing is correct, there is a special procedure for checking and setting the timing for that ignition system
looks mean nothing, when was the dist cap/rotor last replaced?
oddcarout
It got a new cap may 2019, probably has less than 50 hours on it.
what do I need (tools) to check the timing. I will look up the process.
I don’t have any issue at speed, at WOT or crushing. Just the acceleration. Would I still have a timing issue?
oddcarout
How do I check the timing? I can’t seem to find it in the manual without removing the engine.
thank you
nola mike
The timing procedure can be found in the manual at boatinfo.no. I believe that that's one of the distributors that needs to be set to "base mode" by jumping 2 wires. After that you just need a timing light.
But agreed sounds like a fuel issue. Spraying carb cleaner does nothing (unless the carb is disassembled). You need to take apart and rebuild the carb, which is also where you'll find the power valve.
oddcarout
Finally got to boatinfo.no, had to get off the network and use my cell data as it is an unsecured site. And unless I am somehow missing it manuals only got to #4. I have the paper manual that covers 1997 but did t find the distributor timing info as I was trying to read it last night.
all I found was the cam timing.
any help would be great.
dubs283
you have to scroll the grey tab below left/right to access other manuals
you should need #13
definitely need to tear down and rebuild your carb, only way to inspect the power valve and accelerator pump
oddcarout
What does the power valve do?
my accelerator pump is working, I can see the metered fuel come out when I open the throttle.
oddcarout
Thank you to everyone that helped. I wanted to check for a vacuum leak first before I pulled the carb off. My thought was to check how tight the 8 screws in the top of the carb were. They were loose. At least a half turn before any resistance. I tightened them down and did a warmup and then a small test in the driveway. No hesitation, it was there before in the driveway as it was on the water. Water test this weekend but I feeling better.
thank you. Thank you thank you!!!!
