I got an anchor rope caught in props and heard a loud clunk. Stopped the boat, trimmed up and all seemed ok. That day it seemed to have a harder time getting on plane and ran at a bit higher RPM for the speed. I checked the gear oil at the end of the day after I pulled the boat out. It was milky, and a much bigger concern was some large flakes of metal in it. Going to drain it this afternoon. I will pressure test it first, then I assume I need to try to find/inspect damaged gears. I haven't opened up an outdrive before. Also, it may have spun a prop and I will check into that as well, but that still isn't my biggest problem at the moment. Any advice on where to start?
I am assuming that at a minimum I damaged a gear(s) and need to rebuild or more likely replace the bad lower or upper unit. So, if you have a 1.95 DP-SM outdrive for sale, let me know as well would appreciate any advice on how to proceed.
Thx
Ian
Thx
Ian
