dahlbergdriver
Thread starter- Joined
- Jul 31, 2020
- 30
1998 Force 90HP
Issue I've been having is that the motor runs great, except when I go from throttle to neutral -- 9/10 times it dies. Starts back up fine, but then I shift into gear, go a bit, and then back off into neutral -- dead.
I've been going through the carb and timing tutorial I found on here and I noticed that I have some fuel/wetness coming from the spot where the enrichment valve comes into the carb bowl. Could this be the cause? Also, the guy in the video (which is great btw) says that vibration will cause the enrichment value to open and close -- I noticed the valve isn't on very tight, so I tightened it.
Thanks for the input.
