You didn't say what year on your engine...makes a difference on type of seal on parts (probably) removed to do the repair. Assuming that seal was ok, the drain plug gasket could be leaking, or not installed. Also vent screw(s) up above the flat plate that goes back over the prop (anti-ventillation plate) may be missing seals.
If it were mine, I'd get a suitable, clean container and drain the foot. Screw is under the gear box bulge on the "foot" plus you have the vent plug(s) I mentioned to remove for the oil to drain properly. 3 questions:
How much oil drained out? Were there any metal particles in the oil, and if it had a magnet attached to the drain screw, how much metal was on it. Was there a gasket (usually aqua blue) on each of the screws you removed to drain the foot?
