15 to go in heat #2 and Harvick is leading Keso, TWT, Bell and Bowyer.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #61 15 to go in heat #2 and Harvick is leading Keso, TWT, Bell and Bowyer.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #62 Harvick wins 2nd heat.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #63 Blaney takes the lead on the restart. We're caution free so far.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #64 GA_Boater said: Blaney takes the lead on the restart. We're caution free so far. Click to expand... Oooops! Blaney and Keso! Keso on the flat slides up into Blaney.
aspeck Moderator Staff member Joined May 29, 2003 Messages 19,479 Aug 9, 2020 #65 Blaney wrecking Keso hurt the picks. No more of my guys are allowed to wreck.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #66 aspeck said: Blaney wrecking Keso hurt the picks. No more of my guys are allowed to wreck. Click to expand... You, FlaCowboy and I have or used to have either Blaney or Keso in our rosters. Yuck!
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #67 Harvick back to the lead after the restart.
aspeck Moderator Staff member Joined May 29, 2003 Messages 19,479 Aug 9, 2020 #68 Now Bowyer and Then Bell ... ouch, I am going the wrong way!
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #69 Bowyer has to pit for bad tire rub. Bell for caution #2. Spins from 10th. Bowyer is the lucky dawg.
64osby Admiral Joined Jul 28, 2009 Messages 6,826 Aug 9, 2020 #70 Bad Brad took out Blaney, my best pick of the day. At least he admitted it was his fault.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #71 29 laps to go and Harvick leads Almirola after passing on the restart.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #72 64osby said: Bad Brad took out Blaney, my best pick of the day. At least he admitted it was his fault. Click to expand... Keso got too far down onto the flat apron and washed out. Too bad Blaney was there.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #73 Truex up to 2nd and 22 to go. #19 is still a second back.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #74 Bowman has a flat and leaves the tread on the track for a caution. 4th real caution. Who will pit with 18 to go.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #75 Almirola pits, he stayed out during last caution. 4 tires and gas. Harvick and the rest pitted on lap 105, 41 from the end. An OT finish will be a stretch on gas, but let's wait and see.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #76 Harvick keeps the lead on restart, but Hamlin is right there. Then Truex and Hamlin fight for 2nd and Harvick takes advantage and pulls away.
aspeck Moderator Staff member Joined May 29, 2003 Messages 19,479 Aug 9, 2020 #77 Hamlin gains on Harvick with 5 to go ... its a race ...
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 9, 2020 #78 Hamlin is trying to close on Harvick - 4 to go.
aspeck Moderator Staff member Joined May 29, 2003 Messages 19,479 Aug 9, 2020 #80 Harvick holds off Hamlin and sweeps Michigan
