- Joined
- Jul 18, 2011
- 19,399
I inherited a 3 HP Yamaha OB a couple of years ago from a relative. The engine had been purchased at the end of the 1990 boating season, winterized and then never used. Single cylinder 3 HP, internal tank. . . . spotless :thumb:
When I first got the engine, it was a bit cranky for having been woken up after 28 years in storage, but after some carb cleaner and a little bit of seafoam in the cylinder to loosen things up, it ran very well. I have been using it on my dinghy to get out to my mooring.
Fast-forward to just recently - all of a sudden the engine would not start . . . no matter what. It seemed like it was flooding . . . Thinking it might have been some contaminated fuel messing up the float valve, I took the carburetor apart and cleaned it out, although it was spotless inside. Nothing really that I could see, but I poked all the little orifices with wire, blew things out with compressed air, etc. and put it all back together.
The engine ran fine . . . I ran the engine in gear in a barrel for about 30 minutes and all seemed good, it now could hold an idle speed in gear, and also would increase in throttle (as much as you can really do in a barrel
I put the engine back on my dinghy, and it initially seemed OK, but very quickly it only wanted to stay running with full choke (or nearly so).
It will go to mid-range speed, powering the boat, but that's about it. If I try to back-off the choke, the engine dies . . . whether in gear or neutral.
So, at this point, I think that something happened to the motor (carburetor) that I am overlooking or not realizing that caused the initial problems. Not sure what it could be :noidea:, but having to run on choke tells me that there is air getting in somewhere other than via the throttle plate. Of course this latest issue seems like the opposite of the initial issue . . . initially getting too much fuel, now not getting enough . . . . :noidea: I adjusted the idle air screw to no avail . . .
Since I'm at a loss for next steps, I thought I would post the issue to see if anyone has some ideas or similar experiences and possible causes.
