Nextelbuddy
- Joined
- May 4, 2020
- 163
my boat originally came wit ha 13.75 x 21p propeller with my 1:62 alpha 1 gen 2 drive.
currently it has a 14x19p quick silver prop.
right now i can only get a consistent 4200 rpms and 35-36mph confirmed by the onboard speedo and GPS speed app on my phone.
my 5.7 mercruiser engine has a max RPM of 4600 rpms according to the sea ray prop guide PDF and also othe rwebsites confirmed this as well.
would going back to a 13.75x21p help get me back to 4600 rpms and hopefully into the 40mph range?
i bought my boat second hand and previous owner said they replaced the engine and it onyl had 2 hours on it but now after going through it i can tell it has not been replaced but instead they most likely just added an edlebrock intake manifold and 4bbl carb and thats it.
the engine runs ok, it feels a bit tired if anything but it doesnt stutter or misfire it seems.
if i go from idle to full throttle there is a definite LAG you hear and feel before it starts moving but its not a stutter, almost like a pause
i checked the throttle cable and at full throttle, the throttle plates in the carb appear to be opening fully
i plan on ordering and replacing:
8 MR43T plugs
quicksilver spark plug wire kit
quick silver cap and rotor
new ignition coil
quick silver fuel filter
i wondering if doing the above maintenance items PLUS the original spec 13.75x21p SS prop I can get back to 4600 rpms and into the 40+ mph range.
I consistently see other owners if 1996 sea ray 210 with 5.7 engines getting into the 50mph range.
i'm also hoping that getting more speed on plane back will help with the annoying porpoising the boat does at full speed on the water
8 MR43T plugs
new ignition coil
