Motor will not run below 1200 rpm. What is best way to clean carbs?
follow the factory service manual, take them apart, soak in carb cleaner, chase every passage, re-assemble and adjust per manual.
A lot of those motors have high and low speed stator windings. You might ohm them out and make sure both are good.
If the low speed stator winding is bad, the motor will not run at 2000 rpm or lower
