1lastweekend
Thread starter- Joined
- Nov 7, 2015
- 71
I have a 1981 Rinker V170 with the Mercruiser 120/2.5L motor. For the last year, the lower unit will drift down to the full down position within a few minutes of being raised. This boat has the Prestolite trim pump in it. I have checked the trim rams, lines and pump, does not appear to be any leaks and the oil level in the pump is staying full. I think it is the check valve ball/spring assy in the pump body. Luckily I have another pump assy where the motor went bad a few years ago, so I swapped it out for a used one from a local boat salvage place. I have this one on the bench now, but not fully disassembled.
I want to make sure this pump body is functioning correctly before I swap it in for the other one. Does anyone know how I should take it apart to prevent the pieces from coming out, and then not understanding how they go back together? Also how can I tell that there is leakage past the shutoff that would cause the leg to drift down? I appreciate any advice!
