I just inherited this motor, and unfortunately the previous owner removed the lower unit AND completely disassembled the water pump housing and everything inside it.
I am now attempting to put the water pump housing back to how it's supposed to be and found 2 white plastic washers (see pictures) that I thought would go under and above the impeller. However, I could not slide these washers onto the drive shaft (see pictures) because the hole of the washer is smaller than the diameter of the shaft. I also looked at the parts diagram (link below) and found what I think is this washer. If someone is familiar with this particular motor, please let me know how to proceed. By the way, I have ordered a manual on eBay but it will take about two weeks to receive it.
https://www.crowleymarine.com/parts/5826.cfm
Thanks in advance.
Dustin
Thanks in advance.
Dustin
