Scott06
- Joined
- Apr 20, 2014
- 7,485
Yes a 4.3 cannot use all 600 cfm would be interesting to see how far the air flap On the secondaries opens at wot.
mike I’d get the tach straightened out before you lose sleep on the top end. The 4.3 should be able to rev higher than the 3.7 did up to like 4800-5000. See where u are at wot rpm.
also I would think the 4.3 added some weight vs the 3.7 you mention 50 hp this has vortex heads with the 8 bolt intake? What was the hp on the orig8nal 3.7, have you checked that you are getting full ignition advance ? By like 3 k rpms you should have 22-26 degrees total. I think a stock 190 hp vortec 4.3 with Tbolt ignition had 8 deg Initial and 16 degrees advance off the module.
